Sat, Feb 1, 5:38 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Subject: P4 Patch bug...
rbtwhiz ( ) posted Wed, 29 December 1999 at 11:15 AM ยท edited Sat, 01 February 2025 at 5:38 PM
Just wanted to get a collective input one whether or not anyone else hase found this. I've been making a point to try each thing that was supposed to be fixed with the "unoffical" patch. Durring my "testing" I've found the fixed "NudeInfant" to infact not be fixed. If you turn on the "genitals" switch, the geometry does get replaced with the correct file but... instead of the the hip using the "skin" usemtl, it uses the "default" usemtl. Easy fix right? Nope. Tried the usual; delete the geometry .rsr and have Poser rebuild it... no dice. Anyone else experience this? -Rob
JeffH ( ) posted Wed, 29 December 1999 at 1:00 PM
The materials in the alternate geometry must be incorrect. In anycase send this report directly to Larry Weinberg as requested on his page. -JH.
rbtwhiz ( ) posted Wed, 29 December 1999 at 1:19 PM
Jeff, my post is to get collective input. I fully intended in sending the report to Larry, but I want to see if anyone else can confirm my finding before I bother Larry with it. I changed the usemtl statement to reflect the correct name, poser will not build a new .rsr for the figure. -Rob
JeffH ( ) posted Wed, 29 December 1999 at 1:25 PM
I'll try it myself and get back to you.
rbtwhiz ( ) posted Wed, 29 December 1999 at 1:25 PM
Thanks
JeffH ( ) posted Wed, 29 December 1999 at 1:38 PM
Yes, I get the same problem with the Materials. It isn't too hard to match the color though. -JH.
Traveler ( ) posted Wed, 29 December 1999 at 4:52 PM
At the end of the .cr2 there is a list of materials, and preset materials, try altering those too. -Trav
nicknoel ( ) posted Wed, 29 December 1999 at 6:09 PM
This may be slightly off subject, but then again maybe not. I e-mailed Larry and got a response to some of my questions regarding additions and such. He said that a Poser -Bryce thing was almost ready but he is still waiting for the Bryce people to finish it. And he said that they will be releasing a SDK for creating plugin apps (they created it primarily so the Bryce team could work up an export filter). Apparetnly there is quite a bit they are working on. And Larry DOES send replys back. I have recieved two replys to my questions. He seems to be going out of his way to be nice, so if you have any problems at all, give him an e-mail. He WILL reply. He said that Ghost Effects is the primary support for the P4 Patch and Poser until it gets picked up by some other company. Nick
Jude ( ) posted Wed, 29 December 1999 at 6:39 PM
Perhaps Larry will read our email and even reply, but let's not wear out our welcome too quickly. I think Rob's idea to check here for confirmation before reporting a problem is a good one. Maybe our forum admins will fix us up with a special place to collect our problems so that each one only has to be reported once. The less time Larry spends answering email, the more he might have to work on what we really want.
rbtwhiz ( ) posted Thu, 30 December 1999 at 1:48 AM
Thank you Jude, for seeing exactly my point. I wanted see if it was a problem throughout the community before I took up Larry's time. Eric, I've already altered the .cr2. In any case, that wouldn't fix the current problem. The problem is with the geometry and poser not building a new geom .rsr for the figure. Thanks for the suggestion though. nicknoel, thanks for the info. My concern wasn't with wether or not Larry would reply, though I appreciate your assurance. I just want to do some of the trouble-shooting before I forward my findings to Larry, so it makes it less time consuming for him (this way he can continue to fix other functionality problems). -Rob
