Mike 1 and 2 should be identical meshes. Set the sharp teeth morph on Mike 2 only, no other morphs, then export the head only as an OBJ. Deselect all tickboxes except "save as morph target" then save it and load it onto Orc Mike then it should work fine. This assumes the Orc Mike you have is vanilla, ie you haven`t edited it and re-stitched the head onto the origianl model.
This may be a silly question, but... I have an Orc for Michael model and would like to know, if I could use Michael 2 morphs on the orc model (Michael 2 has a sharp teeth morph and i'd like to see it on the orc). Thanks!
