Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 09 11:05 am)
The files in that download are morph targets in .obj format. Load Vicky into Poser, select her head, then select Properties from the Object menu. On the Element Properties panel, you should see a button called Add Morph Target. Click it. Locate one of the morph targets you've downloaded, give it a good Label name, and click OK. Go back to the head dials, and you should see your new morph added to the list.
I just recently got Poser, and I saw where MorphWorld was back up. Well, I downloaded a file 5 Fae / Youthfull face shape morphs for Vickie. I did buy Vicky 2 and have successfully installed it. My question is, how do I use/access these morphs? Do I need to copy the files anywhere special? I am asking here as I figured everybody but me would know. :-)
