Mon, Feb 3, 9:06 PM CST
Subject: Newbie question about morphs, I think
Jcleaver ( ) posted Tue, 29 January 2002 at 8:32 PM ยท edited Mon, 03 February 2025 at 6:15 PM
I just recently got Poser, and I saw where MorphWorld was back up. Well, I downloaded a file 5 Fae / Youthfull face shape morphs for Vickie. I did buy Vicky 2 and have successfully installed it. My question is, how do I use/access these morphs? Do I need to copy the files anywhere special? I am asking here as I figured everybody but me would know. :-)
Little_Dragon ( ) posted Tue, 29 January 2002 at 9:37 PM
The files in that download are morph targets in .obj format. Load Vicky into Poser, select her head, then select Properties from the Object menu. On the Element Properties panel, you should see a button called Add Morph Target. Click it. Locate one of the morph targets you've downloaded, give it a good Label name, and click OK. Go back to the head dials, and you should see your new morph added to the list.
Jcleaver ( ) posted Wed, 30 January 2002 at 8:04 AM
Thanks. I guess I was actually doing everything right with the exception of giving a good name for the label!
melanie ( ) posted Wed, 30 January 2002 at 8:40 PM
Once you have the morph target installed on Vicki, you have to resave Vicki to the library, or the next time you goback into Poser, the morph target won't be there. Be sure that the morph is set to 0 before you save it, though. Melanie
