Fri, Feb 7, 12:57 AM CST
Forum Moderators: Staff
Subject: Poser SKIP FRAMES
Ericroy ( ) posted Tue, 29 January 2002 at 11:01 AM · edited Thu, 30 January 2025 at 8:15 PM
Does anyone know how to set the Poser defaults so that the skip frames feature is always off unless selected? Or, if that can't be done, is there a way to disable it permanently? I hate it! Thanks, Ericroy
geep ( ) posted Tue, 29 January 2002 at 4:28 PM
... Try setting a Poser file (while it is loaded) to the "skip frames" in the condition you want. Now, under "Edit" ---->"General Preferences" ... click "Launch to Preferred State" click "Set Preferred State" click "OK" Now, go to ... "File" ----> "New" and when Poser reloads, see if the "skip frames" is in the condition that you left it. Just a guess - see if it works. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Ericroy ( ) posted Tue, 29 January 2002 at 6:52 PM
I've tried that before, but I just tried it again to be sure... that doesn't do it. In my opinion, that should do it, but it doesn't. Thanks, Ericroy
geep ( ) posted Tue, 29 January 2002 at 8:12 PM
... it is probably an "internal" default setting in Poser and you'll just have to live with it. Sorry! cheers, [anyway] dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Ericroy ( ) posted Wed, 30 January 2002 at 5:04 PM
Well, I emailed Poser Technical Support (DUH! I know... I should've done that first). The manager there says that it can't be done, but that he/she'd like to see that option, as well. So it goes. Ericroy
geep ( ) posted Wed, 30 January 2002 at 7:27 PM
... anyone????????????? ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Ericroy ( ) posted Thu, 31 January 2002 at 5:58 PM
Poser5 sounds good to me. If we start a wish list, do you suppose they'd listen to us. I like Poser, but I could go on and on about 'improvements'. A few big things, but mostly a lot of little ones. I shouldn't get started, well, here's a little one: how about a 'recent file' shortcut list like every other computer application? Oh well, that's just a little annoyance. Ericroy
