Wed, Nov 13, 11:05 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: jagged edges on text done in spline modeler
hartcons ( ) posted Tue, 05 February 2002 at 7:37 PM · edited Wed, 13 November 2024 at 11:04 PM
I just tried carving some text into a block in the spline modeler but the end result has a lot of jagged edges on the text (look at the "e" for example). Is there any way to get the edges of the text smoothed out? I think I just used Arial font for this test. Are there some fonts that work better for this than others?
JasenJ1 ( ) posted Tue, 05 February 2002 at 8:36 PM
Crank up the Surface Fidelity under the Geometry menu. Try around 1000%. - Jasen.
hartcons ( ) posted Tue, 05 February 2002 at 8:53 PM
That's more like it.
hartcons ( ) posted Tue, 05 February 2002 at 9:32 PM
Is this surface fidelity something that needs to be cranked up on every object (on a per-object basis) to get a nice smooth looking scene?
MarkBremmer ( ) posted Wed, 06 February 2002 at 5:32 AM
Yes. Just like you can determine the number of facets for VM objects, surface fidelity controls the number of facets "made" when a spline object is rendered. In RDS the maximum spline fidelity was 400. In carrara it is 1000. I'm not sure whether it is truly a greater fidelity or just more control.
TOXE ( ) posted Wed, 06 February 2002 at 7:46 AM
Hey Mark! In Carrara the maximum surface fidelity in the spline is 5000. Or my copy of Carrara is completely crazy? :-) Toxe
MarkBremmer ( ) posted Wed, 06 February 2002 at 9:15 AM
I learn something everyday! :)
