Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 3:34 pm)
Hey this is cool. Just what is it you do want it to do. I may or may not be able to offer up some code ideas. I write HTML/Javascript for a living. I'm viewing it in netscape and like what I see so far.
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
One problem I noticed. The size of the images will always equal the first one loaded and that is causing some of the smaller images to warp. You could fix this by having it swap out layers rather than images. But this would mean ALL the images would have to preload and that's a long download. Otherwise you will have to make all the images the same size to avoid the warping. Or use a combination of layers (DIV tag not netscape LAYER tag) and image swapping if you can group the images into a small number of layers by pixel size. You should also have the display image in it's own table cell rather than just aligned right. If my window is too small right now it blocks out some of the choices.
Renderosity
Gallery
Attached Link: Backstage
I made it a little bit more netscape friendly... but unfortunately... netscape just lacks a lot of features that stop me from being able to do the stuff that I wanna do... oh well... anyway.. on this site you will find everything that I ever rendered in 1999 and decided to save to disk... some of it sucks... some of it's good... some of it is posted around the net.. but it's a fun trip none the less...
