Mon, Dec 2, 2:20 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: Poser eyelashes
Calseeor ( ) posted Sat, 09 February 2002 at 10:14 AM ยท edited Fri, 29 November 2024 at 10:47 PM
Hello all, When I import poser 4.2.1.179 (with propack installed) figures into vue 4.03, they eyes are alwats outlined in a thick geometry, that I am assuming are the eyelashes. There does not seem to be a way to make the eyelashes import correctly, or not at all. Even if I flatten them in Vue, they still appear. This causes a weird effect around the eyes that I need to painstakingly paint out. As you can not edit the textures on the individual componants of the face, I can not just simpley retexture them or add transparencies. Am I missing something? (I probably am). Thank you, Eryk
sittingblue ( ) posted Sat, 09 February 2002 at 10:18 AM
It has been my experience that the eyelashes import with 50% transparency (thick geometry). You can edit the eyelashes by using the Material Summary (F6 shortcut). Charles
Charles
MikeJ ( ) posted Sat, 09 February 2002 at 10:47 AM
yeah, first check to make sure that the transparency (in Vue) is set to 100% for the eyelashes, through the Material Summary window, not the World Browser).
Calseeor ( ) posted Sat, 09 February 2002 at 10:57 AM
great information, thank you both. I will try that. :) --Eryk
raven ( ) posted Sat, 09 February 2002 at 12:02 PM
Are you using the standard P4 figures? Because I don't think they have the transparency option that Michael and Victoria have. I could be wrong though :)
Calseeor ( ) posted Sat, 09 February 2002 at 1:01 PM
I was actually using victoria and some spin offs of her. The F6 shortcut that Charles mentioned works like a charm. :)
Ainle ( ) posted Mon, 11 February 2002 at 9:17 AM
Something I've gotten in the habit of doing as well is to set the eyelashes to not cast shadows (or is that "not to cast shadows"?)
Calseeor ( ) posted Mon, 11 February 2002 at 9:29 AM
now that is a good idea. I will try that as well. it may help to stop problems in the future. Thank you Timberwolf.
