Fri, Sep 20, 12:24 PM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
Subject: This MUST be an old problem...
ArmoredGideon ( ) posted Mon, 11 February 2002 at 4:56 AM ยท edited Fri, 20 September 2024 at 10:46 AM
Hi guys!!! I've just been tinkering around trying to get my Poser figures (Michael 2+ hi res-textures) to go into MAX 4. First I export the figure form Poser4 in 3ds format-then import into MAX4 (no problem). Then using the MAT editor I apply the Michael textures-still looks okay. But, then I render the image and lo and behold if 1, the entire texture appears split along the seams and 2, you can see the outlines of the individual bodyparts in the texture! I can't fix this no matter what I try. I've seen other tutorials for Max 3 which call for you to export your figure from Poser as an Obj.File and then import to max3, but this involves downloading an Obj-to-max plugin, but this pluging won't work with MAX4!!! If there is anyway to get around this problem without having to buy yet another 'special' program (to do something that these already massivly expensive programs should do anyway) PLEASE let me know as I can't be the first to have this problem. :( Thanx M8's
ArmoredGideon ( ) posted Mon, 11 February 2002 at 5:03 AM
Oops! I meant to post this in the 3ds max Forum. Still, any advice would be grand :)
JeffH ( ) posted Mon, 11 February 2002 at 11:52 AM
Use OBJ format instead of 3DS.
mwa ( ) posted Mon, 11 February 2002 at 12:10 PM
There is a version of the obj plug-in for max 4 Magnus
mwa ( ) posted Mon, 11 February 2002 at 12:25 PM
http://www.maxplugins.de/cgi-bin/read.pl?config=r_r4.pl&ptype=Import&sort_a=author&matches=10&page=1 Here is a link just scroll down to HABware and you will have one importer and one exporter.
