Wed, Dec 4, 11:07 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 9:51 am)
Subject: Help! I'm missing my neck.
webraiders ( ) posted Mon, 11 February 2002 at 3:11 PM ยท edited Wed, 04 December 2024 at 10:56 AM
Hey can someone tell me what I did wrong? Here's what I did. I took a character that I found in to Poser. Then used the front cam and then resaved the character. I then opened UVMapper and loaded the character. I then started using "select by material" and moving things around. After I got everything moved where I wanted it I saved a new model and template. Pulled the template into Photoshop and added my texture, I had sure everything that needed to covered was. But when I went back in to Poser, as you can see no neck! I pulled the character into the demo of UVMapPro and loaded the texture and everything looks as it should (I think!). Help!
aleks ( ) posted Mon, 11 February 2002 at 3:19 PM
delete the *.rsr from geometries folder that goes with the *.obj for your figure. it gets corrupted sometimes. i assume that you are not using propack?
PhilC ( ) posted Mon, 11 February 2002 at 3:25 PM
Check that your new OBJ actually has a group called "neck". My favorite typo in UVMapper is to make a selection then instead of going to Assign to Material I erroneously select Assign to Group. My guess is that you have assigned the neck to a group called "skin".
hauksdottir ( ) posted Mon, 11 February 2002 at 7:26 PM
Boy, is there going to be one surprised vampire when he sinks his teeth into... emptiness? ::tee-hee:: Not having a neck to stick out might save this lady some grief over the long run. All kidding aside, after you check to make sure that you do have a group called "neck", make sure that it is visible. Carolly
