Fri, Nov 15, 2:52 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Help me bis !
olitoth ( ) posted Tue, 12 February 2002 at 8:48 AM ยท edited Fri, 15 November 2024 at 2:27 AM
Me again, Thanx Helen for your tips but that not works. When I take a cloths, my model's deleted again... The message when I double click on the cloths : "the current figure contains customized goemetry". "keep modified geometry ?" YES "keep props etc...." YES. And, Bum ! no way... XXX Oli. ps : what's it a "Double Ticks" ?
Lisas_Botanicals ( ) posted Tue, 12 February 2002 at 8:52 AM
By double clicking on the clothing you are replacing your model. That is what the "the current figure contains customized geometry" pop up means. Select your clothing item. At the bottom of the library panel you will see 1 check mark, 2 check marks a "+" and a "-". Click on the 2 check marks to create a NEW clothing figure. If you click on the 1 check mark you will Replace your figure. Hope that helps! Lisa
tasmanet ( ) posted Tue, 12 February 2002 at 9:05 AM
Double Ticks
olitoth ( ) posted Tue, 12 February 2002 at 12:37 PM
Hello Lisa, thanx ! Okay, I have 4 options : -change figure -create new figure (double ticks) -(+) add to library -(-) delet from library. I click on the double ticks and that's works for the rain coat but for the shoes (see the pic below my message for see the result...). The shoes are not "magnetised" on the foots. It's not automatic ? Thanks again, you save me :) Oli
Lisas_Botanicals ( ) posted Tue, 12 February 2002 at 12:48 PM
Hi Oli, With the shoe selected, go up to the File menu and choose, "Figure/Conform To/" A window will pop up. From that choose your Model which is probably "Figure 1" in this case. Select the other shoe and do the same thing. That should help you! :) Lisa
leather-guy ( ) posted Tue, 12 February 2002 at 3:30 PM
It usually helps to scale a bodypart(like a foot) smaller or make it invisible to keep it from sticking out thru clothes or shoes. Good Luck
olitoth ( ) posted Tue, 12 February 2002 at 4:48 PM
***Yay, thanks for your help Lisa ! XXX Oli. ***For Leather-guy : Why "good luck" ? Just what I thought... it's more easy to dress the Barbie of my sister :o)) Thanks for your suggestion, I'll try it to :)
