Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
By double clicking on the clothing you are replacing your model. That is what the "the current figure contains customized geometry" pop up means. Select your clothing item. At the bottom of the library panel you will see 1 check mark, 2 check marks a "+" and a "-". Click on the 2 check marks to create a NEW clothing figure. If you click on the 1 check mark you will Replace your figure. Hope that helps! Lisa
Me again, Thanx Helen for your tips but that not works. When I take a cloths, my model's deleted again... The message when I double click on the cloths : "the current figure contains customized goemetry". "keep modified geometry ?" YES "keep props etc...." YES. And, Bum ! no way... XXX Oli. ps : what's it a "Double Ticks" ?
