You can't just copy them into the folder. They must go in specific folders, which the unzipped document should be showing you. For example, a folder marked "textures" should be opened and checked for sub-folders. If one appears, then that is moved to the textures folder in your runtime. Same thing with geometries and libraries. Once they're properly installed, you shouldn't have anyt problem accessing them.
Attached Link: http://www.renderosity.com/~pzr/extensions.html
The files have to go into special folders. At the link is a description. PS: The Poser Forum FAQ (top of this page) has some more answers to Poser questionsAttached Link: http://poserutils.tripod.com/index.html
Also try PInstall. PInstall is a standalone application which allows you to install poser library objects (characters, poses, textures, etc) without needing to figure out which files go in which Poser subdirectory--PInstall does it for you. You don't even have to unzip library files stored in zip archives. Also, you can use PInstall to unzip and install a variable number of archives automatically!This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hi, as a new user to Poser 4 could someone offer guidance on how to use downloaded props, object files. I have unzipped them, copied them into a folder within Poser but nothing shows. What am I doing wrong? I would assume that this question has already been asked before but rather than trawl through the forum could someone offer me some advice now as a big favour (e-mailed replies would be gratefully appreciated)? Many, many thanks in advance. DA in the UK
