Thu, Feb 6, 5:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: export an vrml-file
strahlemaus ( ) posted Mon, 18 February 2002 at 10:14 AM · edited Thu, 06 February 2025 at 5:49 PM
hi, maybe this is a very silly question, but i'm new in poser and don't know. what do i have to do for exporting a vrml-file? greetings rebecca
VirtualSite ( ) posted Mon, 18 February 2002 at 10:34 AM
I don't remember if that's on the list of available formats (and I don't think it is), but to export anything out of Poser, you go to File -> Export..., and a window box pops up asking you what format. Now I suppose (assuming that VRML isn't one of the available formats) you could export Poser into some sort of intermediary program that can, for example, take an .obj file and convert that into VRML, but I have no idea how that would affect things like transparency.
strahlemaus ( ) posted Mon, 18 February 2002 at 10:40 AM
merci! i will try it!
poserpro ( ) posted Mon, 18 February 2002 at 1:18 PM
the vrml export in poser is static sequences of wrl, not an animating one. if this is what you need.
poserpro ( ) posted Mon, 18 February 2002 at 1:19 PM
better use low-poly like the ones for propack or avatar lab.
poserpro ( ) posted Mon, 18 February 2002 at 1:29 PM
export in poser.
poserpro ( ) posted Mon, 18 February 2002 at 1:30 PM
vewing in 3d exploration of RH.
poserpro ( ) posted Mon, 18 February 2002 at 1:31 PM
viewing in cortona of PG in IE. Note, tranrparency can be edited with the Transparenct node with textpad or vrmlpad.
poserpro ( ) posted Mon, 18 February 2002 at 1:32 PM
typo: Transparency node
strahlemaus ( ) posted Mon, 18 February 2002 at 3:38 PM
merci poserpro, do you know if there's another possibility to export a poser animation-file and later convert it into vrml. which poser-export-formats does support animation? maybe u know a solution?! merci rebecca
poserpro ( ) posted Mon, 18 February 2002 at 3:48 PM
de rene, rebacca. I tried before, no solution, you have to edit the Coordinate Interpolator by thy own with the info exported from Poser of Propack. There used to be a Italien character animation package called Zapa which do cool VRML animation for character, but it is obsolete. The other way is to export keyframed obj or wrk and import in 3ds max or cinema 4d to use its default morphing featuer to create the naimation to export as wrl. Let me try. Later
poserpro ( ) posted Mon, 18 February 2002 at 4:23 PM
Use max to do morph then export as wrl might be a possible way. Cinema 4d no works, no animation for vrml 97.
