Thu, Feb 13, 5:39 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 5:20 am)
Subject: shadow in wrong place...
triceratops2001 ( ) posted Tue, 19 February 2002 at 12:45 AM ยท edited Mon, 10 February 2025 at 11:35 PM
I got a model in 3DS format, and use it as the background. Then I found the shadow never appear in the right place. I made sure that the figure is standing on the background, but the shadow always goes away. Can anyone tell me what I did wrong? Thanks!
thgeisel ( ) posted Tue, 19 February 2002 at 12:56 AM
The modell is not placed on the plane your seeing. Raise the 3DS obj till the feet of the guy slightly disapear in the floor. When you import the 3ds file select"invert normals" maybe there is a second plane that is invisible now,because the normals are un the wrong direction. Can happen in modelling programs
JeffH ( ) posted Tue, 19 February 2002 at 1:16 AM
Yes, the figure is floating above the floor.
triceratops2001 ( ) posted Tue, 19 February 2002 at 1:33 AM
thanks , I have check that the normal plane is correct, and I try and put the guy into the 'background'... the shadow still goes away...
JeffH ( ) posted Tue, 19 February 2002 at 1:37 AM
Okay, that's very strange. Have you tried this by constructing a floor and wall from the cube props in Poser?
triceratops2001 ( ) posted Tue, 19 February 2002 at 1:57 AM
I told a friend to made the background in 3DS max, it was not the frist time this happen, but the last time , I just hope to made a floor , so I use a box from props library. The problem was avoid. This time , I hope to avoid the line appear at the place two box joint together, so I use this thing, and the shadow goes away.....
Staale ( ) posted Tue, 19 February 2002 at 6:06 AM
Poser has a problem with scale, so if yoou have increased the scale of the firgure inside poser then that might be the problem, make the object larger when you import it.
Hiram ( ) posted Tue, 19 February 2002 at 9:24 AM
Do a search on "background" in the free stuff area. Bloodsong did a similar prop a while back that you might be able to use.
triceratops2001 ( ) posted Tue, 19 February 2002 at 12:41 PM
thank you very to all of you :)
hauksdottir ( ) posted Tue, 19 February 2002 at 6:58 PM
This is not meant as sarcastic, but Peter Pan lost his shadow and Wendy had to stitch it back on to his feet with needle and thread. (OUCH!) If I got an image like your first... I'd be loading a couple of characters and a Victorian sewing box.. If you accidentally get a weird effect that others have to sweat to achieve, try to make use of it. We have magical sparkle lights because somebody's earrings blew up, and who knows what other lab accidents became products or tutorials. Carolly
