Tue, Nov 26, 8:07 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 6:57 am)
Subject: Do I need speacial prog. to turn 3DS into posable prop?
Tashar59 ( ) posted Thu, 21 February 2002 at 2:32 AM ยท edited Fri, 22 November 2024 at 7:16 PM
Can use poser to turn 3ds file into a posable prop or do I need a different program, and if so what do you recommend. I try FAQ but old phone lines, thus it takes a year or so to find things. Thanks for your help. Tashar 59
leather-guy ( ) posted Thu, 21 February 2002 at 2:57 AM
Picture is worth a thousand words. Import the mesh, then save to props library of your choice.
Tashar59 ( ) posted Thu, 21 February 2002 at 3:04 AM
Thank-you very much.
leather-guy ( ) posted Thu, 21 February 2002 at 3:04 AM
To make it poseable is another matter - Depends on what the prop is, whether you need morphs orparenting separate props together, or what. If you post a pic, I'm sure someone here can help you figure out the best course to take. Also, you really should consider checking out the Tutorials link above - you'll learn so much about what's possible.
Tashar59 ( ) posted Thu, 21 February 2002 at 3:28 AM
I would like the flaps and tail to move. FAQ and tuts I check first before I ask questions, so maybe I missed something.
thgeisel ( ) posted Thu, 21 February 2002 at 3:36 AM
There are some good tuts , one is at www.sams3d.com the other at www.posertech.com If the flaps and tails parts are seperate groups its very easy, if not , you have to use the grouping tool to make sepate props out of them,make a hierarchy and than continue
leather-guy ( ) posted Thu, 21 February 2002 at 3:55 AM
If you made the model originally and you're more familiar with 3DS than Poser's grouping tool, you could also try chopping out the moveable parts in 3DS & importing separately. Then you could position them in Poser, parent them to the main mesh, and set them up to pivot as you want (you may need to move the origins to make them move properly). This is the method I've used to make prop doors pivot as around a hinge in a prop doorframe. Another, probably better method is in the excellent tutorial at SAMS3D (see Link) it tells you how to make an OBJ poseable (you can export the prop as an OBJ, if needed)
Tashar59 ( ) posted Thu, 21 February 2002 at 4:18 AM
Thanks I was just there and D/L the tut. Thank-you for you help. Tashar 59
leather-guy ( ) posted Thu, 21 February 2002 at 4:37 AM
Attached Link: http://www.sams3d.com/Tutorial.htm
Kevin It's more than a pleasure. Keep us informed of your progress? Good Luck!
