Fri, Feb 7, 6:56 AM CST
Subject: Download trouble.
Myske ( ) posted Sun, 24 February 2002 at 11:25 PM ยท edited Fri, 07 February 2025 at 6:30 AM
When I try to download from the free stuff area, other than my own All I see is a white screen with a small block in the upperleft corner. Something wrong? Myske
Varian ( ) posted Mon, 25 February 2002 at 1:17 AM
When you click a download button in free stuff, it should open a new window in your browser that is blank and then you should get a dialogue for the file. Sounds like maybe something is strange with your browser. It could just be something that can be cleared up by closing the broswer and re-opening it. If that doesn't help, close the browser, log off, then reboot your system and try again. If neither of those routes help, you might need to reinstall the browser. Try the first route first, and hopefully that will do the trick. :)
Myske ( ) posted Mon, 25 February 2002 at 1:42 AM
It was that way Yesterday but I will try again with another browser. thanx. Myske
Bop ( ) posted Mon, 25 February 2002 at 4:15 PM
errr... I don't know, but this could have two reason : - don't use the "open in a new window" option (or shift+click on the link), this could cause problems. - if you try to use a download utility (getright or others), close it and try again. Scripts cause problems on this apps... hope it can helps... :-)
Myske ( ) posted Mon, 25 February 2002 at 11:00 PM
Thanx for the advices, I think I know. IE 6 is crashed ,using Oopera last night and now it works. regards Myske.
