Thu, Jan 23, 8:51 PM CST
Subject: From Posable to Conformable?
MDibble ( ) posted Tue, 11 January 2000 at 5:48 PM ยท edited Thu, 23 January 2025 at 8:47 PM
Back in the ancient days of Poser 3 :) people were creating posable clothing. Can anyone tell me what steps I'd have to go through to convert these posable CR's to conformable CR's? Thanks! Mike
WarriorDL ( ) posted Tue, 11 January 2000 at 5:55 PM
This is based on the idea that your posable clothing Poser files are pp2's. Change the extention to cr2 and move them to your clothing folders. Then load up your default figure you want the clothing on, and then load from your menu (NOT import) the posable clothing. Then go to the "Comform to" and try comforming it. I have never tried this, so I have no idea if it will work or not. Again, this is assuming the files you speak of have pp2 extentions.
MDibble ( ) posted Tue, 11 January 2000 at 5:59 PM
I tried to just conform the posable clothes (which are already CR2's) and OY! did that not work! Try Anton Kisiel's Wizard Robes. It gets all squinched up at the chest. Mike
WarriorDL ( ) posted Tue, 11 January 2000 at 6:18 PM
..hmmm I have his rope, so I'll give it a try. However, this might be the problem- Make sure the Figure 1 (ONE, the figure the robe is comformed to) is selected before posing.
WarriorDL ( ) posted Tue, 11 January 2000 at 6:19 PM
...err I have his robe, not rope L
Kalypso ( ) posted Tue, 11 January 2000 at 8:36 PM
Site Admin
I know renapd conformed the Amidala dress and steveshanks also made the victorian dress conformable. They said they had to edit the cr2 file so that's probably the only way to really get it to conform. The victorian dress works great now.
nicknoel ( ) posted Wed, 12 January 2000 at 3:34 AM
Wouldn't renaming the parts to the names of the limbs do the trick too? I mean like in a skirt, even if it only had one piece calling the hip part "hip" and the adominal part "abdomen" and so on work?
steveshanks ( ) posted Wed, 12 January 2000 at 7:36 AM
Take the cr2 of the catsuit open it in wordpad and edit the two references to the obj to point to your new obj (the poser3 item) then save as newname.cr2 and check word didn't cal it newname.cr2.txt if it did just rename it.......just use the relace command in wordpad......Steve PS typed this in a hurry if you need more just yell :o)
MDibble ( ) posted Wed, 12 January 2000 at 8:43 AM
Thanks, Steve! I'll use the Tuxedo for the male clothes. :) Mike
steveshanks ( ) posted Wed, 12 January 2000 at 1:17 PM
Yep best choice Mike......BTW you can delete all the material references in the CR2 so you don't have ones that are irelivant in the material editor......Steve
WarriorDL ( ) posted Wed, 12 January 2000 at 10:57 PM
Regarding the robe and posability- Something I discovered on it: No thigh groups. I added thigh groups in, and it posed/conformed great. To use the tuxedo cr2 file for the robe, there is a lot of info you will definatly need to remove- All info regarding the head, neck, hands, shins, feet and toes. And I do mean ALL info on those.
