This is based on the idea that your posable clothing Poser files are pp2's. Change the extention to cr2 and move them to your clothing folders. Then load up your default figure you want the clothing on, and then load from your menu (NOT import) the posable clothing. Then go to the "Comform to" and try comforming it. I have never tried this, so I have no idea if it will work or not. Again, this is assuming the files you speak of have pp2 extentions.
Take the cr2 of the catsuit open it in wordpad and edit the two references to the obj to point to your new obj (the poser3 item) then save as newname.cr2 and check word didn't cal it newname.cr2.txt if it did just rename it.......just use the relace command in wordpad......Steve PS typed this in a hurry if you need more just yell :o)
Regarding the robe and posability- Something I discovered on it: No thigh groups. I added thigh groups in, and it posed/conformed great. To use the tuxedo cr2 file for the robe, there is a lot of info you will definatly need to remove- All info regarding the head, neck, hands, shins, feet and toes. And I do mean ALL info on those.
Back in the ancient days of Poser 3 :) people were creating posable clothing. Can anyone tell me what steps I'd have to go through to convert these posable CR's to conformable CR's? Thanks! Mike
