Fri, Nov 22, 8:37 AM CST
Subject: Animated Flame
cmmyakman ( ) posted Tue, 12 February 2002 at 9:29 PM · edited Thu, 01 August 2024 at 1:06 PM
I'm launching a missile and need to make an animated flame emanating from it. Does anyone know how to do this and explain it to a goombah (me)?
Nukeboy ( ) posted Wed, 13 February 2002 at 1:22 PM
I don't know from goombah's :-), but here goes: Create your flame object (I've used the rock generator to build complex flame shapes) then apply a good volumetric texture like Clay's Fire. During your animation, lengthen/shorten and rotate the object in each frame. It should come out like the flame is not only flickering, but pulsing, too. HTH
cmmyakman ( ) posted Wed, 13 February 2002 at 1:34 PM
Cool, thanks for the info, I'll give it a try. The rock generator is an especially good idea, because my cones are too symetrical.
pigat ( ) posted Fri, 01 March 2002 at 9:57 AM
I used the rock generator to create a engine flame using a blue volumetric flame texture the rock was duplicated enlarged slightly and a blue glow texture was applied to it i also added a small radial light with the same blue flame texture as a gel, the main rock with the fire texture was rotated during the animation plus the texture was also rotated and sized during the animation. Hope this helps
cmmyakman ( ) posted Fri, 01 March 2002 at 10:18 AM
That sounds like that process will generate a true flame. I'll give it a try. Thank you very much.
