Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 03 5:29 am)
This is normally caused by the OBJ file for that item of clothing/character being missing. To see what this OBJ file is, and where it should be do the following: Open the .CR2 file in a text editor, and search for 'obj'. The path is normally in the format: :runtime:geometries:whatever:thefile.obj In your mind replace the : marks with (directories), and check if the OBJ file really does exist. Hope this helps!
Perhaps the clothing that is being loaded has a texture and trans map applied that requires its transparency being set to 100%. You won't see it when it's loaded but will see it when it's rendered. This type of clothing usually shows up as a mesh of tiny dots. Try rendering the scene and see if the clothing shows.
Does anyone have a problem in Poser where you try to put an article of clothing on a character, and the object doesn't show up even though it says its there? What do you do about this????
