Sat, Feb 15, 1:22 PM CST
Subject: Transparency help..
Kiera ( ) posted Tue, 05 March 2002 at 10:39 AM · edited Sat, 15 February 2025 at 1:22 PM
Is it possible to load a transmap and have the visible portion of an object be translucent? If so, how do I go about it? I want to just just the skirt portion of this dress as part of a bigger outfit, and I want the red section to be translucent and the white section to be completely transparent.
VirtualSite ( ) posted Tue, 05 March 2002 at 10:42 AM
If the dress is built in pieces, like "top" and "skirt", then you can make the top invisible by selecting it in the materials window and setting its transparency for 100%. You can also look in the hierarchy window and see if it's in pieces there (like left collar, right collar, chest, and abdomen) and turn them off. Failing all that, you can easily build a transparency map to apply to just the top.
3-DArena ( ) posted Tue, 05 March 2002 at 10:43 AM
gorgeous dres. I would think that if the two areas are seperate materials you could do that, simply make the red portion only slightly transparant...
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use.
-Galileo
Kiera ( ) posted Tue, 05 March 2002 at 10:50 AM
Alas, the dress is all in one piece. I was thinking of "fudging" it by using black and white pixels alternated on the skirt portion (I use this technique to make boxes translucent in web design) but I was hoping someone had a more elegant solution for me. ;) I don't understand remapping all too well.. I suppose I could redo the materials using the grouping tool in Poser to separate out the top portion?
For my image to work I need to be able to see the legs of the bodysuit through the skirt.
Kiera ( ) posted Tue, 05 March 2002 at 10:52 AM
Ooh, good idea on the heirarchy editor. Let me look into that. =)
Valandar ( ) posted Tue, 05 March 2002 at 10:55 AM
Umm, greyscale pixels show up as translucent.
Remember, kids! Napalm is Nature's Toothpaste!
Kiera ( ) posted Tue, 05 March 2002 at 10:58 AM
The heirarchy thing helped (saves me the trouble of dealing with transmaps for the extraneous portions of the dress) but I am still not sure how to load a transmap AND make the skirt translucent. As you can see, I have cut out some sections of the dress using a transmap. Poser is so irritating sometimes. =D This should be simple.
Kiera ( ) posted Tue, 05 March 2002 at 10:59 AM
I tried grey, but it didn't do anything. Does it have to be a specific grey value?
Kiera ( ) posted Tue, 05 March 2002 at 11:05 AM
A-hah! Thanks Valandar, I figured out what I was doing wrong. My "grey" wasn't *really* grey. On a hunch I converted the transmap to greyscale and it worked.
Thanks guys. =)
3-DArena ( ) posted Tue, 05 March 2002 at 11:09 AM
now I'm confused are the colours on the dress above the defaults? I thought they were 2 different "materials"
-Galileo
Kiera ( ) posted Tue, 05 March 2002 at 11:13 AM
Nope, I was using the red to block out my transparency map so I could see what I was doing better.
SAMS3D ( ) posted Tue, 05 March 2002 at 11:39 AM
Can't you split the skirt apart in UV mapper and make your own groups? That is what I do? Sharen
Kiera ( ) posted Tue, 05 March 2002 at 12:06 PM
Yeah, I could. But this works. I wanted to make it as easy as possible. I am doing an EverQuest portrait for a friend of mine and didn't want to go through remapping and such if I could avoid it. =D
brittmccary ( ) posted Tue, 05 March 2002 at 12:16 PM
Can you split it into two groups in UV mapper (you're a PRO now, you know! g), and then use the group tool in Poser, - assign materieals to each group.. That might work. Britt
