Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 14 10:57 am)
If the dress is built in pieces, like "top" and "skirt", then you can make the top invisible by selecting it in the materials window and setting its transparency for 100%. You can also look in the hierarchy window and see if it's in pieces there (like left collar, right collar, chest, and abdomen) and turn them off. Failing all that, you can easily build a transparency map to apply to just the top.
gorgeous dres. I would think that if the two areas are seperate materials you could do that, simply make the red portion only slightly transparant...
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same
God who has endowed us with sense, reason, and intellect has
intended us to forgo their use.
-Galileo
For my image to work I need to be able to see the legs of the bodysuit through the skirt.
The heirarchy thing helped (saves me the trouble of dealing with transmaps for the extraneous portions of the dress) but I am still not sure how to load a transmap AND make the skirt translucent. As you can see, I have cut out some sections of the dress using a transmap. Poser is so irritating sometimes. =D This should be simple.
![file_283392.jpg](https://live.cdn.renderosity.com/forum/threads/599703/file_283392.jpg)
Is it possible to load a transmap and have the visible portion of an object be translucent? If so, how do I go about it? I want to just just the skirt portion of this dress as part of a bigger outfit, and I want the red section to be translucent and the white section to be completely transparent.
