Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 7:29 pm)
Yes. ERC will do it. You must insert the script, Poser will not convert the rotation channels for. Set all of your morphs to the closed position and create a Full Body morph. Make a note of the degrees of rotation. Save the prop file. Open it in EditPad and copy the five lines for the ERC and paste them into a same location in the target rotation channel(s). The DeltaAddDelta for the rotations will probably be 1/degrees.
If Jim Burton's research holds, #1 will fold #1 & #2, # 2 will fold #3, #3 folds #4, etc. If the morphs and rotation channels in question, have their names changes to end with _0 (including the figure in the ERC script) and a Find _0 Replace with _1 (_2) (_3) etc and each saved to the library, then no cross-talk. But yes, Duane, you are right, there will be cross-talk, unless some provision is made. Does the null figure work for props?
Attached Link: http://www.nerd3d.com/Tutorial/SuperMorph.htm
As I read the thread, it occurred to me that a prop-making newbie might get the reference to ERC, but a Poser 4 newbie might not. The link explains the concept.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
What I would like to have is just 1 dial, for "folding" the chair. Right now, I use a morph for the 2 pieces of cloth. (on which you sit, I don't know the proper english word) a morph for moving one of the arm-rests, and rotation dial for both legs.
To fold it up, I first rotate the left legs downwards, then rotate the right leg, then I move the arm-rest sideways so that it is located on top of the right leg again, and then fold the pieces of cloth. It works, but it's not a very elegant solution :-))
Is it possible to combine all that in just one dial?
