Did you try Edit mesh? If not click on the E icon next to the selected mesh. It will take you to the edit mesh dialog box where you'll want to crank up the red bar then click on smooth. That should do it. DOGA is a program that has pre-made parts for assembling a model. Neal
Okay - I have done that a few times... however, it still isn't doing anything... Ie the side edges of the body just arn't going to change to something more smoother... I was hoping the it would round the edge but it doesn't wanna (I might have to remodel it I think :( ) Um - okay DoGA is a premade model parts then - for animation - any one used it? Why would I think about using it? I'm looking for things to help make models, and to help do textures. Tracy
Tracy, To smooth, you must left click on the smooth sphere at the left. You'll see the polygon's count beeing displayed there. Edit/smooth is a weird function. It doesn't smooth some corners in low polygonal count meshes because, as you can't bend a polygon, there's nothing else to smooth. Look at your mesh and try to figure out if it's possible to smooth the corner without bending any triangle. If you already tried angles greater than 90 deg, the only way is to go back to your modeling program and round the corners. BTW, what did you use for modeling?
Never used Rhino Tracy. What if you make some boolean with cilinders along those edges to rond them? I'm sure I've been to some sites with Rhino tutorials, but can't remember where :( My advice: repost your tank and your question to 3D app forum, and don't forget to mention your Rhino problem. Sorry for not beeing able to Help. Nandus
