Forum Moderators: RedPhantom
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 18 2:22 am)
RDS eliminates materials (usemtl ___) You can change it to g before you open the model and convert it back after, either in a TE or with UVM. But straight out of RDS and into Poser, you get one texture = preview. You want a nightmare? use the bottom option on open. RDS converts the usemtl to g for you, a different one for each instance, so a two or more materials alternate, each instance is a different group. It does keep the mapping, but if you mess arround with naming groups very much, it might reverse normals on some of them - very difficult to repair.
Here is the model opened in a text editor but I am not sure what to change? #Created using Ray Dream Designer(R) 5 mtllib stone2.MTL v -7.01206731 -14.99985694 -11.83717727 v -7.01206731 -14.99985694 12.56016921 v -7.06114435 -14.99985694 12.56016921 v -7.06114435 -14.99985694 -11.83717727 v -7.06114435 10.00846290 12.56016921 v -7.06114435 10.00846290 -11.83717727 v -7.01206731 10.00846290 12.56016921 v -7.01206731 10.00846290 -11.83717727 vn 0 -5.00166416 0 vn -0.00981545 0 0 vn 0 5.00166416 0 vn 0.00981545 0 0 vn 0 0 4.87946939 vn 0 0 -4.87946939 g Cube usemtl Cube f 1//1 2//1 3//1 f 3//1 4//1 1//1 f 4//2 3//2 5//2 f 5//2 6//2 4//2 f 6//3 5//3 7//3 f 7//3 8//3 6//3 f 8//4 7//4 2//4 f 2//4 1//4 8//4 f 3//5 2//5 7//5 f 7//5 5//5 3//5 f 1//6 4//6 6//6 f 6//6 8//6 1//6
There is no vt section? Poser will work fine with no vn section, but I don't know about the vt (I keep forgetting what data the vt section contains.) You have a material = cube So if you open the materials window and apply the stone texture, it should show up, unless vt is needed. Poser provides, but does not use mtlib files as I understand it.
![file_283873.jpg](https://live.cdn.renderosity.com/forum/threads/602043/file_283873.jpg)
I've created my model in RDS 5.5 When I save the model as an obj file I set the options box to export texture maps. When I import the obj file into Poser 4.0.2 it also brings the texture with it, but when I render the image, no texture shows. I do have "use textures" checked in render options. The model will not show any other texture either. I wonder if it is possible to go direct from RDS to Poser without using UV Mapper (a most excellent program, like you didn't know that!) Thanks!!! 8)
