Thu, Nov 14, 1:24 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
Subject: Question about conforming clothing
sjk77 ( ) posted Tue, 12 March 2002 at 3:44 PM · edited Thu, 14 November 2024 at 1:23 PM
I read somewhere that if you change the figureResFile line in the .cr2 file of the person you want the clothing item to conform to to the new clothing's .obj file that it will conform well. But obviously that can't be all. Can you change the joint parameters on the clothing and still have it conform? Obviously you would have to delete all the body part definitions that do not apply to the clothing. What else is involved in this process? Is there another/better/easier way?
steveshanks ( ) posted Tue, 12 March 2002 at 3:59 PM
no thats it in the basic sense.....scroll to the bottom and delete the materials too so it picks up your new ones in the mesh......oh oh sorry i just noticed you said person..no no that won't work you must use a piece of clothing similar to yours.......Steve
sjk77 ( ) posted Tue, 12 March 2002 at 4:28 PM
so you mean that I shouldn't change the joint parameters in poser, or does that even matter?
PheonixRising ( ) posted Tue, 12 March 2002 at 4:50 PM
Anything is conformable to anything. It is the parameters that make it fit right though. The joint parameters can be tweaks but should be similar. The joint parameters determine if the clothes will match up with the figure so they should be almost the same if not identical. Anton
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
NEW The Poser FaceInterMixer
bloodsong ( ) posted Tue, 12 March 2002 at 5:38 PM
Attached Link: http://www.3dmenagerie.com/index-goo.htm
nooooo.... not quite. you have to tweak the cr2 of the target figure before it will work correctly. this is a job for.... the Painlessly Easy Conforming Clothing tutorial! quick, to the bloodsongmobile! ::starts playing super hero theme music::
