Sun, Feb 9, 11:13 AM CST
Subject: So, should we use the new patch 4.05?
SAMS3D ( ) posted Tue, 12 March 2002 at 4:10 PM · edited Sun, 09 February 2025 at 11:11 AM
Just wanted to know how you all like the 4.05 patch, is it worth installing? Sharen
MikeJ ( ) posted Tue, 12 March 2002 at 4:23 PM
Well, I've been saying for weeks that it is. I've been using it since the day of it's final release...4.05-02, that is. Try it. If you don't like it, you can use the "Back" folder to go back to 4.03. Make a separate copy of that Back folder first, before patching. The only thing I have a problem with is the new Object Import window. It's not standard Windows, and you can't do alot of things in it which you can do in windows, including read folder properties, delete files, copy/paste..that sort of thing. And rcreating a new folder doesn't work so well either. Actually, the problems with that window are rather annoying...
markm ( ) posted Tue, 12 March 2002 at 6:40 PM
I think I had a similar problem to what Mike had . Mine would only show little black boxes for the folders when trying to load a file and it would only load directly from the Vue folder. I went back to 4.03 , it seems to be the most stable for me . I will be really glad when they get this thing fixed , it's a great program when you can get it to do what it's supposed to do .
MikeJ ( ) posted Tue, 12 March 2002 at 6:47 PM
Yeah, I didn't have the Black Box thing until recently. THAT is really bugging me! It started after I changed my options in Windows Explorer, and the next time I opened Vue, all my folders look alike. Gone are all my icons....just black boxes. GRRRRRR!!!!
TheDaedalus ( ) posted Tue, 12 March 2002 at 10:50 PM
I totally hear you guys on this one! What a mean, mean problem! I think other than that, though, and the fact that you can no longer select straight MAT files as materials (like the base plant materials), the upgrade is a fine one. Personally, it's a requirement for me, because it's the first version that accepts BUM files properly on my system. Oh well. Aaron
gebe ( ) posted Wed, 13 March 2002 at 3:51 AM
To get rid of the black boxes : Go into your folder where the black boxes comes from (i.e. Objectsfurniture) and delete the "obj.prv" file everywhere, also in the 'pure' OBJECT folder. This is without risk because Vue will create a new one as soon as you use the folder:-). Guitta
MikeJ ( ) posted Wed, 13 March 2002 at 6:31 AM
Hi Guitta, No, that's not what I meant. You're talking about the black boxes in Vue's own library collections. I only had that happen once, and I did delete the .prv file and it fixed it. This screenshot is what I'm talking about. It happens when browsing folders, through the Object Menu>Import Object dialogue. Also I see it in whenever I have to go into other directories looking for textures or whatever. The top one is Vue 4.05-02. The bottom one is how it should look, from Vue 3.1. No other programs are doing this, so it's not me....just Vue.
gebe ( ) posted Wed, 13 March 2002 at 6:38 AM
Oh, Mike. This happend to other users who had installed 05 over 03. But not when 05 is installed directly over Vue 4 first edition or Vue 4.02-02. This may be the reason. Guitta
MikeJ ( ) posted Wed, 13 March 2002 at 6:56 AM
No Guitta, it just suddenly started happening, well after I had been using it with the .05-02 patch WITHOUT this problem. I can even pinpoint exactly when it happened. When Kate was talking about her problems with Vue and Win 95 and didn't want to install Win 98. There was talk about folder options, something about columns versus rows, so I went into Windows Explorer out of curiosity, and changed a few settings. The next time I opoened Vue, this is what I saw.
gebe ( ) posted Wed, 13 March 2002 at 7:03 AM
Thats too bad Mike. And you don't remember the setting you have changed, of course. Maybe Steve could give you a solution ? Your screenshot above looks really bad. My Windows is french, but there is a feature to change that again. The problem is, I dont know the english words for it. Give me an hour or a lottle more, because I have to finish a work, then I will try to explain with my french screenshots. Guitta
MikeJ ( ) posted Wed, 13 March 2002 at 7:06 AM
Thanks Guitta! Take your time, I've gotten used to it looking like this. ;)
SAMS3D ( ) posted Wed, 13 March 2002 at 7:19 AM
Okay, I guess everyone has answered my question. I just don't think enough has changed to update, and I do not like that black thing, that would drive me nuts. I wonder if the operating system has anything to do with it. Oh well, I guess I don't really need to update, all seems to work well now. Thanks for the help...Sharen
gebe ( ) posted Wed, 13 March 2002 at 9:07 AM
If you go to your desktop,this should work;
MikeJ ( ) posted Wed, 13 March 2002 at 9:26 AM
Thank you Guitta! I'll try that soon. I have a Vue picture rendering right now, which I'm gonna put in the gallery after it's done. But I'll try this then and let you know if it works. Thanks again. :)
bloodsong ( ) posted Wed, 13 March 2002 at 9:50 AM
heyas; wellllll..... actually, it's not worth killing mike over. but a catchy title, huh? i put on 4.05. (STOP running away!) now... i don't know if any of you guys noticed this, but since 4.0, my vue has been a little.... off with control handles. that is, when i want to select a sizing handle on the top or side of my object, i have to move the cursor about 10-15 pixels above the handle, in order to get it to select the handle. that, i could deal with. NOW, i had this patch of grass and ALL the handles for the crazy thing were about 30-50 pixels above the actual objects. AND when i used the top handle to vertically size it, the blasted grass jumped up and down as if it were really in that box up there, not where it was. and you shoulda seen me trying to grab it and drag it. i have to grab way up there, inside the handles, to grab the grass which is down on the ground. sheesh! oh, and using the anchor option didn't help, either. well, can't complain much (yah, right!) since it rendered an image and actually saved it for once. am i too late to try to render mine for the mystical thing? :/
MikeJ ( ) posted Wed, 13 March 2002 at 9:54 AM
LOL! Yeah, I've had that happen, but with terrains, not veggies. Not too late..the challenge goes until the 19th. :)
MikeJ ( ) posted Wed, 13 March 2002 at 10:15 AM
Guitta, It didn't work. That's OK though, because like I said, I'm used to it, and I know what I've got anyway, and where it all is. Now, if it wasn't showing anything, I'd be a little concerned! Maybe the next patch will fix their fancy new import windows...
Varian ( ) posted Wed, 13 March 2002 at 2:07 PM
Nah, don't kill Mike for that, but I've got that problem too. For me, it's most noticeable on the side handles, which I have to grab about 10 pixels above the actual handle. Any object, kind of annoying, but...another little thing. shrug
markm ( ) posted Wed, 13 March 2002 at 2:40 PM
My problem was what Mike has except in my case if I tried to load a saved scene that was stored in another folder outside of Vue it would not open the folder .
bernieloehn ( ) posted Wed, 13 March 2002 at 4:25 PM
Sorry - but I seem to be the only kind of conservative here because after reading about all these patch troubles (already .03 etc.), I decided to wait for the release of Vue 5 - and I don't have any problems with the original Vue 4 version. Well ... Yours, Bernie
Keep cool and fight for the right of others
to have a different opinion than you have!
;- ) Bernie
MikeJ ( ) posted Wed, 13 March 2002 at 4:50 PM
Hmmm... I can open .VUE scenes from other folders in other directories. Don't know what to think about that, but this is all starting to get weird. :/
hein ( ) posted Thu, 14 March 2002 at 1:39 PM
I had problems with V4 from day one, had them till V4.03, updated to 4.05 and seem to be running an extremely stable V4 at the moment, since 4.03 I can even import Poserthingies but who needs that with the new radiosity scripts. The last crash I had was before 4.03 and I usually push every button in sight. What I don't try to do is run the thing in openGL mode, because the Nvidia cards aren't too good at that and I've no need for shady previews.
MikeJ ( ) posted Thu, 14 March 2002 at 2:55 PM
There's something reaally strange about the "open GL" in Vue. I updated my Voodoo 3 driver again today, and EVERY app I have which uses open GL is looking better, and moving slightly faster, it seems, games too. Not Vue thoughg...nooooooo-oooooo not Vue. Vue crashes the instant I try to select wireframe in any window. I've been using the open GL in the camera window, but that's it. Otherwise it's too slow. The only way I can use Vue now is to just disable open GL entirely. No big deal, though, as having all the other programs run better is worth it.
Christoph1 ( ) posted Thu, 14 March 2002 at 6:32 PM
Yeah, OpenGL sucks with NVidia drivers. Is there anyway to disable it in Vue, or to select Direct3D?
MikeJ ( ) posted Thu, 14 March 2002 at 6:46 PM
You can't select D3D, but you can disable Open GL in File menu>Options. You have to close and restart Vue before the change will take effect.
