Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Seriously lalverson...its Windows98. It can't deal with Poser's memory issues very well. That 512k of ram may sound good, but Windows9x can't deal with it. It was designed when home PC's never had that much RAM, and its choking on its own design (Microsoft has articles about these issues if you want to look them up). I installed XP and now scenes that wouldn't render have no problems. If you don't whan to change your OS, you can get cacheman (search downloads.com) to tweak some Windows settings that will help...but it won't cure the base issue.
I would except that if not the fact that I have rendered images with 27 figures in it using billy-T clothes, mike and both versions of vicky, with high resolution texture maps. Granted win98 is nto geared to decent memory management, however, I have tried this on XP and 2K as well and they have failed as well. Now XP and 2K have better memory management, however, that doesn't correct how poser deals with memory, which is the same regardless of the OS.
I had trouble with Stephanie locking up my machine when rendering (but it was not always reproducible) Finally, I shrank my textures down to 1/2 their original size (had planned on doing that any way, don't need the larger files just yet) and it hasn't been a problem since. I've used other textures of the same size, but perhaps these have a higher color depth or the bump map is considerable larger (mine were the daz hi res maps) eric
I have been attempting to use Steph and other vicky and mike characters. All my attempts have failed. has anyone seen or experienced this? for specifications athalon 1000 processor 512 mb sdram win98SE Poser4 Prop Pack (sr3) The test; One mike with clothes, wedge hair One vicky (1 or 2) with clothes, sanfranciso hair One Stephanie clothed, with sassy hair one sofa prop Poser default lighting (three area lights. with the mike and vicky and sofa it takes 2 minutes to render. with the addition of the steph poser locks and will not render
