And for the hair, you need to get involved with the materials editor. Make sure the texture is applied (Diffuse/Ambient - column A) then apply whatever bump map you're going to be using in column B. Finally, load the transparency map into column C and select "blend transparency" from the little drop-down menu. This also works for Allie's transmapped curls. If you still have a problem, please contact me, and I'll send you more detailed instructions Paul
It looks like the the texture on the bryce figure didnt load or possibly the poser figure had a lot of color to the materials in there (Ie the skin was already shaded a tan) but I think it was that bryce didnt load the materials ... On my Mac to get them I need to put them all out in the open on the main hard drive window to get them to be applied. Good luck
The 'hair behind the ear thing' is a dial/morph in Kyoko hair #2 (or at least that's what I call it). Look around on the Poser Factory page. You can do 'short', 'long', behind right ear, behind left ear, bangs, etc. Working with Allie's or Kyoko hair in Bryce is a 'challenge' LOL--several weeks ago there was a thread or 2 on it in the Bryce forum. Diane B
I don't see another post from you Vile. Also--why don't you bring this up in the Bryce forum again--I can't honestly remember who was involved in the discussion but he had a decent answer. A discussion about transmaps would be a good thing. I remember when I first did Anton's peacock with the transmapped tails. What a nightmare until I figured it out. I actually printscreened and printed it out (the 'material lab) so I wouldn't forget and I referred to it doing the Kyoko hair but there are several layers and it sort of confounds the whole thing. Might be a really good thread. Diane B
From the looks of things Vile you might have the gamma correction turned on in Bryce. Gamma works fine for snow scene's and such, but washes out the poser figure's texture. As for the T-Map workaround it's relatively simple and works very well in Bryce. If you want to email me for the instructions then I can better explain it to you. bhuffman@citynet.net
