Mon, Feb 10, 1:55 PM CST
Subject: Windows XP and Poser Pro Pack What the smurf is goin' on!?
Mister13 ( ) posted Tue, 19 March 2002 at 8:39 PM · edited Mon, 10 February 2025 at 1:52 PM
Anyone else running windows XP with NTFS and only able to get whole numbers on their dials in Poser pro pack? Ive tried the sensitivity setting (it only accepts whole numbers as well). Ive tried everything even going to curious labs and received no response. Wondered if I was just alone and theyre laughing at me or if anyone has found themselves kneedeep in this mess. Thanks Mister13 P.s. a quick response is needed as I am saving up money for a trip to crotch-punch Bill Gates over this if I cant get it working. P.P.S. Please note that even if you do want to see Gates crotch-punched it would hurt me as a person not knowing the solution to this problem.Thanks.
ElectricAardvark ( ) posted Tue, 19 March 2002 at 8:50 PM
Go for the crotch punch...I run XP with FAT32 without that problem. FYI
starmkr ( ) posted Tue, 19 March 2002 at 8:50 PM
I am running Windows XP and Pro Pak with NTFS and have not had that problem. I what I did need to do was reinstall the Metacreation Poser 4 with out patch then update with Poser Pro Pak...then Service Pak 3. The system is running great under XP except for being a memory hog.
Jackson ( ) posted Tue, 19 March 2002 at 8:53 PM
I have the same setup but not your problem. This is way off the wall, but have you looked at your Regional Settings in the Control Panel?
Nance ( ) posted Tue, 19 March 2002 at 10:17 PM
Just curious - is it really not accepting the values, or just not displaying them?
soulhuntre ( ) posted Tue, 19 March 2002 at 10:54 PM
I have not had the problem... and if there WAS one then the bug would be in Poser anyway. The file system should not have an effect on math rounding. I LIKE NTFS, I use the dynamic partitioning and disk striping. On top of all that it is much safer than Fat32 :)
Mister13 ( ) posted Wed, 20 March 2002 at 2:02 AM
ok here's what ive tried (re-installing) 3 times (both poser and pro). Im running NTFS under XP with a 60 GB Hard drive (dunno if it has anything to do with it. Regional settings smell ok. And it is neither displaying nor excepting anything except whole numbers.Service pack 3 isnt helping :(
MadYuri ( ) posted Wed, 20 March 2002 at 2:05 AM
I have Pro Pack, Windows XP and NTFS. I don't have your problem through. Does it affect all dials? Does it affect the scale/rotation dials?
aleks ( ) posted Wed, 20 March 2002 at 2:57 AM
my guess is that you have for a decimal delimiter "," (semicolon) instead of "." try changing this in your system prefs.
cylui ( ) posted Wed, 20 March 2002 at 7:14 AM
It maybe your graphics card...what is your graphics card? You may need to update your graphics card driver or call tech support. Graphics card always do such a strange things or try to use standard VGA driver and test it to see if you have that problem first.
Ironbear ( ) posted Wed, 20 March 2002 at 9:56 AM
Deinately crotch punch Bill. ;]
"I am a good person now and it feels... well, pretty much the same as I felt before (except that the headaches have gone away now that I'm not wearing control top pantyhose on my head anymore)"
  • Monkeysmell
thorntoa ( ) posted Wed, 20 March 2002 at 10:53 AM
Add me down as another XP, NTFS, ProPack user with no problems. Also, since you mentioned drive size, I have a 100GB drive.
Allan Thornton
Penguinisto ( ) posted Wed, 20 March 2002 at 11:04 AM
Online Now!
For what it's worth, my laptop is using Windows 2000 Pro w/ NTFS and ProPack... I can manually enter my dial settings out to 5 decimal places without incident :) /P
gstorme ( ) posted Wed, 20 March 2002 at 3:24 PM
Kick Bill!
Jackson ( ) posted Wed, 20 March 2002 at 4:46 PM
After all this, is it possible the source of the trouble might be P.E.B.K.A.C.? (Pronounced pebkak).
Mister13 ( ) posted Sat, 23 March 2002 at 3:48 AM
PEBKAC eh? Thanks for the help wise a**. Doubt it, all I did was install the thing. Although I am curious and want to know more about the decimal delimiter . I am not sure where to look. I do appreciate the genuine help you guys have given me.
Jackson ( ) posted Sat, 23 March 2002 at 11:32 AM
Sorry if I offended, but my thought was sincere. It's happened to me a few times where I tore my hair out over a problem...tried everything...only to find it was something simple I was overlooking. Like a new 21" monitor not working...then realizing I'd forgot to plug it in.
Jackson ( ) posted Sat, 23 March 2002 at 10:15 PM
Mister13: To find the decimal delimiter, go to Control Panel and open Regional Settings and click the Customize button.
