Mon, Dec 2, 6:25 AM CST
Subject: File paths in MAT files
plmcelligott ( ) posted Fri, 22 March 2002 at 2:34 PM ยท edited Mon, 02 December 2024 at 6:18 AM
When ever open an existing MAT file, the file paths for the texture maps all use a ":" as a path divider. When I save a character and open it, the divider is the usual DOS "" character. Is it necessary to replace each "" with a ":"? Also, does Poser allow for spaces in the path or file names? I ask this because I've been trying to make MAT files for the DAZ Combat Map Pak and there are spaces in the default names and folders and I have been having problems.
Routledge ( ) posted Fri, 22 March 2002 at 2:48 PM
The ":" is a MAC version of a PCs "". PCs read both fine so its your choice really. MACs need it to be ":" I believe. Spaces definitely are allowed, they work on all my stuff. The whole path should be in ":Runtime:textures:...etc", I think they`re called parentheses. Keep trying B) Mark
plmcelligott ( ) posted Fri, 22 March 2002 at 2:49 PM
Ok, thanks.
Dave71 ( ) posted Fri, 22 March 2002 at 3:14 PM
It is actually better to remove the path all together, I always make my paths just ":texturename" Poser will automatically search the textures directory for it.
plmcelligott ( ) posted Fri, 22 March 2002 at 3:29 PM
Even better. Thanks guys.
scifiguy ( ) posted Fri, 22 March 2002 at 4:29 PM
Apparently Poser will search the texture directory regardless of what the path says. I opened an existing clothing MAT file to compare it to one I was trying to make and was having trouble with. I was shocked to see a full cProgram Filesetc. path reference. My poser isn't even on my C drive, its on my D drive. Yet that MAT pose works just fine despite the full path to a non-existant directory. I bet it goes slower than having the right info in there, but at least I now know that Poser can still find textures even if the paths are messed up. Too bad Geometry references aren't that fault tolerant.
EricTorstenson ( ) posted Sat, 23 March 2002 at 1:01 AM
I'm pretty sure cleaning up some old MATT files (by putting the correct directory path) sped up the load process for me. I stick with the :runtime:blahblah even though I use windows, since that is the way most of the stuff that came with poser read. eric
