I had a problem installing the patch. I got an error message -- my poser.rsr "is not valid and can not be updated." My Poser 4 is the original,unpatched version 4.0. There's nothing wrong with my current version (that I know of). The only variable is that I installed it in its own directory on my 2nd hard drive rather than in the default folder, but the installer found it OK (just wouldn't complete the upgrade). I also still have Poser 3 on my system, if that matters at all. I'm emailing these notes to Larry as well.
Just installed the patch, and there seems to be some sort of problem with the regular hair. It loads to the default state, and refuses to move together with the head, neither will conforming hair conform at all... But as I said, just installed it, and I'm not even sure it's the patch I should blame, I might have missed something. Gonna take a closer look when I get some time over. Do you have the same problem, Albertosaurus?
Me so, I've just installed the new patch and noticed the following issues: - conformable hair (curly long hair) don't conforms anymore. - normal hair lands always in default position when the figure is posed, also you have to manually parent the hair to the head (Was working perfectly with the 4.0.2.111 beta) I've just emailed this to Larry
Is anyone having any problems with the new patch? Specifically with hair, both conforming and regular.
