Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 12:22 am)
Actually, thinking about it you may have hit one of Posers foibles/quirks. If you are trying to get rid of part of the catsuit on say, the collars, with a trans map AND add a highlight to the same area as well, it appears it can
t be done. The highlight seems to always get priority. Ive seen even marketplace items that have this problem of highlight and transmaps clashing, so even some Pros can
t cure it. I would love to be proved wrong as I would like to do some more work on a hair item that would be massively improved by highlights.
I'm not sure, but I think while I was playing around with making some trim invisible on a French Maid outfit, turning the transparency falloff down to 0 and both transparencies up to 100, that helped. But also, that was on small trim and not a whole bodypart, so it may not work on something larger. Still, can't hurt to give it a shot, ne?
Excellent it worked, it seams you must have something loaded in the texture map box, trans map or a texture map. It didn't work when the texture map's image fills the hole document, but if working in Photoshop and in layers the texture is just applied to the parts of the catsuit u require then flood fill the rest of the document with black that does the trick. Thanxs for everyones help Claire xxxxx
I've just made a transparency map for the V2 catsuit, it transforms the catsuit into a halter neck top, i set all transparencies to 100% so just the top is showing but if i apply a highlight to it the highlight shows up on all the catsuit and makes the see through bits look like plastic wrapping, how can i get the highlight to just appear on the top its self and nowhere else.
