Mon, Jan 27, 12:34 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: Easy available textures
PaulBohne ( ) posted Sun, 24 March 2002 at 8:24 AM · edited Mon, 27 January 2025 at 12:11 PM
Hi, everyone!
Does anybody has an idea, if there is a way copying all textures used in a poser scene into the same folder as the *.obj file while exporting for use in other 3D applications?
Comments are wellcome!
Happy Rendering
PaulBohne
rodzilla ( ) posted Sun, 24 March 2002 at 9:35 AM
hmmmm i know 3dsmax has a function[in the utilities tab] that will do this for you,i'm pretty sure poser doesn't have any funcunality in this area,but other software packages might...what program are we talking about here?
Jaager ( ) posted Sun, 24 March 2002 at 10:32 AM
The geometry and textures can be in any folder. They need not even be in the Poser directory at all. You can put the whole batch in the same folder. The Poser Library files are restricted to the Libraries that match their extensions. If you have the textures applied and move copies to your common folder: Poser does not like it when you try to apply a texture that is the identical name, but in a second location. You must either use a different name, save the Library file with no textures and reopen and apply those textures from the new location, or text edit the Library file after you save it. You can put the geometry and the textures in the same folder with the Library file, and if the only copy of the texture is in this folder, Poser will find it. The geometry path must be precise. Poser does not look. If it is wrong, it punishes you.
boblowery ( ) posted Sun, 24 March 2002 at 7:48 PM
It seem like a good idea to put these textures in the same folder as the obj file when exporting to other programs. If you save an obj or a 3DS from Poser and import that file into Bryce you will have to point to the texture file every time it is called for in the OBJ. If it is in the same folder as the OBJ you will not get this run around. Hope this is right and that it helps. You may have to dig these files up ..... so i guess that the answer to your question may be a "NO"
Lyrra ( ) posted Mon, 25 March 2002 at 12:13 PM
Someplace there'a utility that does this. But for the life of me I can't remember what it was called. Extractor? it was in freestuff at some point. Sorry! Lyrra
PaulBohne ( ) posted Mon, 25 March 2002 at 2:42 PM
Thanks to the above for you kind attention. Especially to Lyrra. I do hope, somebody remembers this utility. Could not find it so far - but using it, what time could be saved.... PaulBohne
Nance ( ) posted Mon, 25 March 2002 at 6:36 PM
IIRC, Yarp said his P3dO_Explorer did something like this. Really don't recall but it either included related files when moving a poser file, or would at least list all the related files so you could go collect them before zipping. Sorry, really don't recall the particulars of the feature & could be mistaken.
yarp ( ) posted Tue, 26 March 2002 at 12:12 AM
Alas not at the moment Nance. I was thinking to such a regroupment but logically, not physically. Luckily next P3dO release will focus on such a feature - I'm making a ZIP installer/uninstaller - so I can also add this regrouping feature, this seems to me a good idea. Available next month... Yarp
Yarp - author of P3DO Organizer for Poser
