One thing you can do is to apply the morphs in Poser and select each body part and go to (in the menu) Object then Spawn Morph Target. Just call it anything (like Duncan, I guess) and save that figure as a new figure to load into the tailor as the base figure. Then all you have to do is just select all the morphs you spawned. Oh yeah, you have to have the genitals turned on in Poser when you spawn the morph target for the hip or else it won't load in the tailor. Hope that helps!
I have a Michael character called Duncan that I got at Renderosity. I put the olypiam (bad spelling!) on him but it didn't fit, so I thought I would go over to the tailor and make it fit. Problem? I don't know what morphs to copy. When you apply the character using an MOR file, the body changes, but the morphs are all set to zero. So I don't know which ones are used. Kevin
