Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
If you examine the lower edge iof the eyebrow directly under the "anomaly" you will see that the anomaly is a repeat of that lower edge. It's like someone rubber-stamped that lower edge of the eyebrow to a position above it. What would cause that aside from being on the texture somewhere, I have no idea. Weird.
Okay, now I'm confused. This evening I was working on an eyebrow transmap for Stephanie myself, and I ran into the same problem. It seems that if I have a transmap for both the UpperEyebrows and the Eyebrows, there is that line above the right eyebrow. If I don't have a transmap for the Eyebrows (only for the Upper Eyebrows), there's no problem, no line. But we should be able to use a transmap for the Eyebrows, too - that's what helps the eyebrow have dimensions to it. And this problem does not happen with Mike, only with Stephanie. Could this be a problem with Stephanie's mapping? Or am I missing something? But how come it does not happen with Mike?
Thanks Mada
...faith, trust and pixiedust
