Fri, Dec 27, 11:51 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 9:24 pm)
Subject: User question re Parameter Dials
nwmione ( ) posted Fri, 29 March 2002 at 8:32 AM ยท edited Fri, 27 December 2024 at 11:45 PM
I use Poser 4.03 but no other programs. I've bought a number of items from the Marketplace where I would prefer that the Parameter Dials were positioned differently. Is there a "simple" way to: 1. Re-position them - Change their order, and 2. To remove one that I don't need. Again, I only have Poser. Thanks for any help
geep ( ) posted Fri, 29 March 2002 at 9:21 AM
  1. no 2. no sorry!
cheers,
dr geep ... :o]
edited 10/5/2019
Lemurtek ( ) posted Fri, 29 March 2002 at 9:53 AM
Depends what you mean by simple. You can delete some parameter dials in the hierarchy editor, click on show all parameters, select the ones you want to delete and hit the delete key. Poser probably won't let you delete the main dials, scale, etc., Taper seems deletable, as most custom morph dials, but you apparently cannot rearrange their order. Poser acts like it will let you drag them around, but it's just yanking your chain. Regards- Lemurtek
Jaager ( ) posted Fri, 29 March 2002 at 12:45 PM
There IS a simple way. You probably will not think it is simple. EditPad (or another transparent TE) You can cut-n-paste morphs in any order you wish. You can delete any that you wish. If you delete channels other than morphs, the figure or Poser may crash, you must try it and see. With any experiment, it is best to change one thing and then test. Morphs can be deleted with not problems. If you paste in morphs for the wrong group or wrong figure, if will get ugly.
dwilmes ( ) posted Fri, 29 March 2002 at 6:45 PM
A simple way is to use the Reorder Dials tool in CR2Edit, but it isn't free. And the current version can have problems with some of the stranger files out there. Dan http://www.zenwareonline.com for CR2Edit, ZenPaint, ZenTile, VueMaster and the complete line of Zenware graphics apps
