Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 27 9:24 pm)
Depends what you mean by simple. You can delete some parameter dials in the hierarchy editor, click on show all parameters, select the ones you want to delete and hit the delete key. Poser probably won't let you delete the main dials, scale, etc., Taper seems deletable, as most custom morph dials, but you apparently cannot rearrange their order. Poser acts like it will let you drag them around, but it's just yanking your chain. Regards- Lemurtek
There IS a simple way. You probably will not think it is simple. EditPad (or another transparent TE) You can cut-n-paste morphs in any order you wish. You can delete any that you wish. If you delete channels other than morphs, the figure or Poser may crash, you must try it and see. With any experiment, it is best to change one thing and then test. Morphs can be deleted with not problems. If you paste in morphs for the wrong group or wrong figure, if will get ugly.
I use Poser 4.03 but no other programs. I've bought a number of items from the Marketplace where I would prefer that the Parameter Dials were positioned differently. Is there a "simple" way to: 1. Re-position them - Change their order, and 2. To remove one that I don't need. Again, I only have Poser. Thanks for any help
