Sun, Jan 26, 10:06 PM CST
Subject: Rendering problems
Fang ( ) posted Fri, 29 March 2002 at 12:05 PM · edited Sun, 26 January 2025 at 9:59 PM
I've been using Poser since Poser2 came out and updated as soon as was finacially viable to where I am today running the Pro pack. I've been encountering problems lately (Just before I purchased PPP)Basically when rendering, sometimes the render progress bar appears and just sits there, normally when using MAT style poses for textures. The only way to get out of this is to Ctrl-Alt-Dlt and Shut Poser down (The amount of work that I've lost due to this and not saving (DOH!) is incredible! I now save before any render I do, but that's a pain as I'm sure you can imagine!) I'm running a P4 1.7gb with 512ram which I upgraded from an AMD of slightly less spec (The AMD pretty much failed on ANY render I did... My question is this, has anyone else encountered this problem and if it's known, is there a fix?
ablc ( ) posted Fri, 29 March 2002 at 12:15 PM
seems to be the old swap problem. Try to go to XP. This release manage memory pretty good. there are several messages on this topic and always the same answer: XP hope it help Laurent
pendarian ( ) posted Fri, 29 March 2002 at 12:33 PM
Win 98 and ME have horrible memory management and have bad memory leaks. I don't have XP but I just went to W2K and there is a world of difference. Don't know what OS you are running, so I can only guess at this point. Pendy
Fang ( ) posted Fri, 29 March 2002 at 12:48 PM
Yeah, I'm running 98SE... I've tried to stay away from upgrading to a diferent OS because I use the PC to play a few games as well. One of which has problems with anything above 98. Oh well, it looks like I'm gonna have to upgrade, I've just this minute lost another character due to this problem (I couldn't be bothered to save first)... It's driving me nutz! Thanks for your help guys Fang
Seravajan ( ) posted Fri, 29 March 2002 at 1:08 PM
I can work very well in WIN ME. I have only very occassional crashes in Vue 4 but this is coming from the program itself. Seravajan
Maira ( ) posted Fri, 29 March 2002 at 1:16 PM
I'm on Win98SE and I didn't have any problems of the sort until a couple of months ago. The problem deteriorated during the last month and I had to re-install Poser 4 after I had deleted all the libraries. After I re-installed it, I deleted the default libraries and installed only the stuff that I actually use. Poser 4 seems to work better now but it still hangs more often than 3 months ago. I'm not sure it's an OS problem as it used to work just fine in the past. If anybody knows the answer, please tell us! :-)
dollpartz ( ) posted Fri, 29 March 2002 at 1:43 PM
Ya I have Win 98 and I've experienced no problems. My system is modest too, 128 Ram .. ah Celeron 566. U might wanna consider reinstallin Windows. Gawd noes whut gets picked up over time ...
Great Bizarro ( ) posted Fri, 29 March 2002 at 1:58 PM
Got any freespace for swap files left on which ever disk you have the swapfile setup on?
cyber-organic ( ) posted Fri, 29 March 2002 at 2:13 PM
I've had the exact same problem. I have Poser on two machines: At work - P3 1Ghz, 256 megs RAM, Win98 SE, Pro pack, and this machine does exactly the same thing you mention. At home - AMD Athlon XP 1700, 768 megs RAM, Windows XP, Pro pack, and it NEVER has this problem. I had assumed that it was either the OS or the fact that my work computer has less processing "muscle" than my home PC, but the computer you're using is pretty close to my home PC, so that pretty much rules that out. Conclusion: In the year 2002, do you really want to be using a 4 year old OS? Time to upgrade.
Maira ( ) posted Fri, 29 March 2002 at 2:13 PM
After I got rid of the useless files in my libraries, I now have a little over 2GB of freespace. I think it's enough for swap files, isn't it?
creativechaos ( ) posted Fri, 29 March 2002 at 3:40 PM
I had the same problems rendering when I was running 98SE, I recently upgraded my OS to Win 2000 Pro. NO problems at all. It's been said that 2kPro isn't for gaming, but I've ran everything from The Sims to Diablo on it and it runs great (better than on 98 actually) If you don't want to go to XP, 2k Pro is definitly a viable option, IMHO.
My Store              My Gallery
Remember...getting lost is the senic route to the eventual destination. (And a lot prettier than the straight road)
lmckenzie ( ) posted Fri, 29 March 2002 at 8:36 PM
You can also set up a dual-boot system and run 2000/XP and 98 for older games that insist on 98.
creativechaos ( ) posted Fri, 29 March 2002 at 9:18 PM
Well yeah, if you have a big enough hard drive. Under 10 gigs it's not really worth it. (Yes there are still people with <10gig drives, I know quite a few) But that would be an easy work around for it. I didn't even think about that lmckenzie
My Store              My Gallery
lmckenzie ( ) posted Fri, 29 March 2002 at 11:10 PM
Yes, personally, I'd rather use a second drive for dual-booting. Even an old 1.2 Gig or 800MB should work for Win98 and a couple of games if you have one hanging around. PriceWatch.com has 30GB drives for $54.00. Unfortunately, it's hard to just run Poser on 10GB if you're a compulsive freestuff collector.
creativechaos ( ) posted Fri, 29 March 2002 at 11:21 PM
30 gigs for 54...hrmm I've been debating on picking up a second drive (JUST in case knock on wood)
My Store              My Gallery
