About dry bush. If you have Vue 4 you should see it in the small preview windows where all the other plants are. If you see the other plants, but not the dry bush (and maybe others missing there??), do the following: Close Vue. Go into your Folder...Vue4Plants Delete the file vegetation.prv Then open again Vue, have a look in the plants. Now it should be there. Deleting the vegetation.prv file is without any risk, as Vue will create a new one as soon as you use a plant. Guitta
Well, actually...no, sorry. False advertising. ;) I'm hoping that with a subject line like that, maybe it will capture Lynn Fredrick's or Steve Bell's attention. So, if either of you see this, how about at least a hint? C'mon guys! Just a hint!
