Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 4:20 pm)
Attached Link: http://www.sams3d.com/Tutroiral.htm
Actually, I don't know why it is doing that, you created the cross as a child to the band part, right, the cross is the child to the parent. Hmmmm, try to adjust it again with the cross hairs with the joint editor up on your screen, then after you set it up, then close the joint editor and see if it is still correct. Try to do this seeing the model as it is, not as a box. Sharen If that doesn't help, go to my site and download my tutorial, it might help you understand doing this. Lots of pictures.Arme, I think your joint setting are not set correctly. I try with some poser standard prop there are two joint settings see as a green cross (the center) and as a red cross the end. With the problem decription you provide it seems that you move only the green cross. Unfortunately you mut move both cross. The reason are: 1- Poser use the two cross for identify the rotation axe. 2- Only the vertices between the two cross are moved. You must put the green one on the ring and the red one at the end of the lower cross. Guy
Together with your helpfull comments, the tutorials from Posertech and SAMS3D I managed to get it posable at last (and learned along the way how to adjust cr2 files and other neat stuff about Poser). On to the texturing now !
Thanks !!
I hope it made some sense and hopefully someone can help me with this.
