You do not need to move anything... simply use your Poser shortcut as usual and all characters will be usable. Simply install Pro Pack as usual. I don't think you needed to install the 4.03 updater, as PP patches everything up to the latest version anyway. If you want a definitive, official answer, contact Curious Labs, as that's what they're there for :) Tilandra
I have an installation problem that is similiar. I had Win98 and installed Poser and the Pro Pack without any problem and have used it for a while. I just recently upgraded my OS to Win2000 and now I install Poser without problems, but the Pro Pack won't work. I get a message about a missing dll file. Anyone know what I am talking about and know how to fix it?
Attached Link: http://www.curiouslabs.com/products/poser4/html/poser4faq.html
Well, that's beyond me. There is a fix for some missing DLLs in the FAQ, but they are different ones, so that won't be much help. I suggest you contact tech support. I know both programs normally run fine in Win2K, because that's what I had prior to XP which I run now. Chris81173, please note there is a section in the FAQ link that talks about your backup folder, also. TilandraActually, I figured out what the problem was. I went to Microsoft's website and used their support database, and it actually had what I was searching for. I searched for msvcp60.dll and it pointed to an article that described the files contained within the support/tools directory on the Win2K CD. All I had to do was install the support tools and low and behold, that funny file was part of the Windows Apps Compatibility Tool. I was able to associate Poser with WinNT 4.0 Sp3 and the program ran perfectly! Guess I need to read up more on Win2K since I am new to it, eventhough I administered networks through WinNT before. Thanks for all your support guys, I really appreciate it!
I have recently purchased a used copy of Poser 4 and Poser 4 Pro Pack and have a few question. First I installed Poser 4, Then when I Intalled the 4.o3 update it created a new folder inside the orignial Poer 4 folder called Updated Save and includes a new poser 4 exe file and some new characters and textures and so on, but all the original poser 4 default characters are in the orignal installtion. Do I need to move all the orignal poser 4 stuff to the updated save folder? Also how dose this effect Poser Pro Pack? if anyone can give me some help on how i should install these 3 programs so the work probably that would be greatly appreciated. thanks chris
