Tue, Dec 24, 7:58 AM CST
Subject: daz mboy cloth problem
ablc ( ) posted Fri, 05 April 2002 at 6:45 AM · edited Tue, 24 December 2024 at 7:31 AM
Hi, I try to make a short with PT pant. If i believe Daz site, it should works with transparency mode. All I got is a ghost pant (see pic). What's wrong ? Laurent
Seravajan ( ) posted Fri, 05 April 2002 at 7:32 AM
Did you use a long pant for it? it seems that you must edit the mesh. Seravajan
ablc ( ) posted Fri, 05 April 2002 at 7:43 AM
i use the long pant, but the daz site isn't very clear about the way to transform it into short pant. Laurent
orphea ( ) posted Fri, 05 April 2002 at 7:45 AM
You might try pulling down the materials menu and looking for a setting that says "long pants" or whatever, then turning off any texture to that material and turning the max and min transparencies up to 100%. That's how it works w/ Vicky's DAZ pants, anyway.
ablc ( ) posted Fri, 05 April 2002 at 7:51 AM
nothing like that :( only pant, without texture Laurent
orphea ( ) posted Fri, 05 April 2002 at 7:56 AM
I don't own the mil kids, so I'm obviously the wrong person to try to help--but what all does it say under the materials menu (top right of your screen shot)? What options does it give you?
ablc ( ) posted Fri, 05 April 2002 at 7:58 AM
this menu contains: capri,short,pant,band and preview short is the first segment, pants is the last pant segment
orphea ( ) posted Fri, 05 April 2002 at 8:00 AM
Just took a look at your pants figure (finally). Try turning the object color to white.
orphea ( ) posted Fri, 05 April 2002 at 8:01 AM
So what you've got now is capri, I guess. If you want shorts, then make the pants and capri segments transparent.
Daio ( ) posted Fri, 05 April 2002 at 8:03 AM
Either make sure the highlight color is set to true black or simply douple click on that portion of the pants and uncheck the visible box in the window that comes up.
"Do not meddle in the affairs of cats, for they are subtle and will piss on your computer." -- Bruce Graham
ablc ( ) posted Fri, 05 April 2002 at 8:09 AM
i tried with true black and then true white and get the same result.
Daio ( ) posted Fri, 05 April 2002 at 8:29 AM
Make sure the highlight size is 0% too
ablc ( ) posted Fri, 05 April 2002 at 8:38 AM
still "ghosty", but i can't get furhter than 1%
Daio ( ) posted Fri, 05 April 2002 at 9:16 AM
You can't? That's odd. I can set the highlight to 0%.
ablc ( ) posted Fri, 05 April 2002 at 9:32 AM
ok. my problem is here. Why can't I turn it to 0 ?
chriscox ( ) posted Fri, 05 April 2002 at 9:41 AM
Laurent, When you set the highlight to true black did you check the RGB values or did you choose the last color under Custom Colors? because the black under Custom Colors isn't actually black. Also make sure that both Transparency Min and Transparency Max are both set tp 100% Chris Cox
Chris Cox
chriscox ( ) posted Fri, 05 April 2002 at 9:44 AM
Laurent, Sorry I see that you already have Trans Max and Min set to 100%. Also just like you my lowetest highligt setting is 1%. Chris Cox
Chris Cox
ablc ( ) posted Fri, 05 April 2002 at 9:48 AM
Darn, I fall in this trap !!! Thanks and sorry for this stupid no-problem Laurent
