Fri, Jan 24, 12:59 PM CST
Subject: How do I do this?
HardRock1960 ( ) posted Fri, 05 April 2002 at 12:16 PM · edited Fri, 24 January 2025 at 6:11 AM
I would like to be able to make a marble floor that has a very shiny and reflective surface. Can anyone tell me how this is done? Also, could you provide me with a good marble material? Thanks for your help!
KenS ( ) posted Fri, 05 April 2002 at 2:20 PM
Attached Link: http://www.chemicalstudios.com
I have several marble textures on my site in the Bryce/Materials section. Ken
HardRock1960 ( ) posted Fri, 05 April 2002 at 4:17 PM
Your response really didn't answer my question. I did follow the link you provided, but couldn't find a section called Bryce/Materials. Maybe I overlooked it, but my first and foremost concern is the method to achieve the shiny reflective surface, not necessarily the material.
Allen9 ( ) posted Fri, 05 April 2002 at 4:26 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=36348&Start=19&Artist=Allen9&ByArtist=Yes
You need to select your marble or whatever material, then in the Material Editor, bring up the values for "reflection" and "Specularity". Those are the two that control how shiny surfaces look. Check out my "Temple of the Moon - Sanctuary" picture (link). The whole place is various types of polished marble (27 hour render, BTW, because reflection - like transparency, eats up the time and makes for long renders).
HardRock1960 ( ) posted Fri, 05 April 2002 at 4:44 PM
Allen9, That is exactly the effect I am trying to achieve!!!!! I do have one more question. Ca the reflection and specularity be overdone? Your example looks great, but I am afraid that I would screw it up. Can you suggest any settings? Does it depend on the material? Thanks a heap for your response!!!!!
Enforcer ( ) posted Fri, 05 April 2002 at 5:59 PM
The only way to screw something up is if you don't like the effect. Some material can begin to look unreal the more reflective they get but go with what you like. Overdoing specularity and reflection can have an adverse effect on your render time though, so when you are rendering your scene I suggect using the TIR option in the Render Options dialog. This way you can limit the number of "Total Internal Reflections" and keep the raytracer from bogging down in infinite reflective loops.
