Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
I've had some problems with that happening with some figures post patch #1. I've yet to install patch #2. I am however NOT saying that it is the problem of the patch.
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
You got the case right? Mine has a capital "P". Umm. Check the .cr2 to verify the geometry location? Import the .obj into Poser to make sure it's okay? Delete the large .rsr? Wow.
Use your Windows Explorer to change the name of the obj file in the Geometries folder, it recognizes the case differences in the names. I was getting a whole mess of files I couldn't open until a friend told me to change the names with the Explorer. My problem is I have several characters that come in with everything EXCEPT the body. The hair and accessories will be floating in space with now body. What's that about. One in particular is a character called Emma Peal and Darkchylde won't come in. Anyone know what's up with that one? Dreamspinner (also scratching head)
Ditch the .rsr in the geometries folder and try again with just the .obj file. If it still will not load take a look at the .obj file in UVMapper or some other application and see if its all there. If you got the one from Traveler's site you know the post was OK, so perhaps zip corrupted in transit. If .obj is OK..... go back and check the names (once again). :-)
The anatomically correct version is available at Morph World. Does anyone remember where the original is? I've forgotten....
It's that classic twilight zone problem..you download the zip, change the um...??? file with Mover into an obj, ya put it in the right geometry directory in all of its case sensitive glory, put the rsr and cr2 in a character folder and...click...cannot open Runtime/Geometry/P4Nudewoman/p4evolution.obj. So, click okay and then "Massive Failure...You are a Poser Loser...forget it Beavis...bub-eye." What is this all about??? everything seems to be in order but no dice. Darth "Head Scratcher" Logice
