Sat, Feb 1, 4:34 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Help! Can't get P4Evolution to work...
Darth_Logice ( ) posted Sun, 23 January 2000 at 6:33 PM · edited Sat, 25 January 2025 at 2:23 AM
It's that classic twilight zone problem..you download the zip, change the um...??? file with Mover into an obj, ya put it in the right geometry directory in all of its case sensitive glory, put the rsr and cr2 in a character folder and...click...cannot open Runtime/Geometry/P4Nudewoman/p4evolution.obj. So, click okay and then "Massive Failure...You are a Poser Loser...forget it Beavis...bub-eye." What is this all about??? everything seems to be in order but no dice. Darth "Head Scratcher" Logice
dlfurman ( ) posted Sun, 23 January 2000 at 6:50 PM
I've had some problems with that happening with some figures post patch #1. I've yet to install patch #2. I am however NOT saying that it is the problem of the patch.
Cage ( ) posted Sun, 23 January 2000 at 8:49 PM
You got the case right? Mine has a capital "P". Umm. Check the .cr2 to verify the geometry location? Import the .obj into Poser to make sure it's okay? Delete the large .rsr? Wow.
Dreamspinner ( ) posted Sun, 23 January 2000 at 11:59 PM
Use your Windows Explorer to change the name of the obj file in the Geometries folder, it recognizes the case differences in the names. I was getting a whole mess of files I couldn't open until a friend told me to change the names with the Explorer. My problem is I have several characters that come in with everything EXCEPT the body. The hair and accessories will be floating in space with now body. What's that about. One in particular is a character called Emma Peal and Darkchylde won't come in. Anyone know what's up with that one? Dreamspinner (also scratching head)
Darth_Logice ( ) posted Mon, 24 January 2000 at 12:25 AM
Dreamspinner...no dice, tried that already. Everything matches the cases is should already. Still Scratching, DL
Dreamspinner ( ) posted Mon, 24 January 2000 at 12:31 AM
Don't know (scratching head vigorously), mine came in just fine after I used Explorer.
Nance ( ) posted Mon, 24 January 2000 at 2:54 AM
Ditch the .rsr in the geometries folder and try again with just the .obj file. If it still will not load take a look at the .obj file in UVMapper or some other application and see if its all there. If you got the one from Traveler's site you know the post was OK, so perhaps zip corrupted in transit. If .obj is OK..... go back and check the names (once again). :-)
Maz ( ) posted Mon, 24 January 2000 at 4:08 PM
Nance's point about ditching the rsr is significant. If Poser has a dodgy rsr it doesn't overwrite it with a better one when you repeat the process. You think you've fixed things but Poser ignores the update.
Rorschach ( ) posted Mon, 24 January 2000 at 5:57 PM
BTW, where can I get the P4Evolution woman? Is it a free download?
Cage ( ) posted Mon, 24 January 2000 at 8:01 PM
The anatomically correct version is available at Morph World. Does anyone remember where the original is? I've forgotten....
Nance ( ) posted Mon, 24 January 2000 at 8:34 PM
I thought that Traveler had posted both Torino's original version as well as the EveWWG version with Hellborn's hip at Morph World.
