Sat, Feb 1, 5:20 AM CST
Forum Moderators: Staff
Subject: deleting lights in poser4
lelionx ( ) posted Tue, 02 April 2002 at 10:56 AM · edited Thu, 30 January 2025 at 4:29 PM
would like to know if there's a way to delete all lights in one clean sweep instead of one at a time. i.e. global lights i may have 20 or more lights.if i switch to another light set i don't always get the same efx as if i had started from a clean set,say with only one light.deleting all those lights is a royal pain.
geep ( ) posted Tue, 02 April 2002 at 5:51 PM
Load a "new" Poser file.
cheers,
dr geep ... :o]
edited 10/5/2019
doozy ( ) posted Tue, 02 April 2002 at 7:53 PM
But that deletes everything else, too!
ScottA ( ) posted Tue, 02 April 2002 at 8:03 PM
What about using the UI dots to save a bunch of different scene layouts with different lighting setups? ScottA
ScottA ( ) posted Tue, 02 April 2002 at 8:07 PM
Ack! never mind. UI dots don't save new lights.
Kiera ( ) posted Wed, 03 April 2002 at 12:15 AM
This is easy. ;) Save your scene with no lights or one light when you are ready to work on lighting. Try presets. If you don't like it, revert to your saved scene. :)
geep ( ) posted Wed, 03 April 2002 at 1:10 AM
Ok, then ... Load your "saved" Poser file. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Preston ( ) posted Fri, 12 April 2002 at 3:46 PM
Well, it's not a perfect solution... I took my standard light set and "turned off" all the lights by clicking off the "On" buttons in properties. I then saved this as a light set. When I want to change light sets, I click on the "Lights Off" set first, then click on the new light set. This turns all the lights off but doesn't remove them. It tends to work even when I have more lights on than I have off (if that makes any sense whatsoever). It's imperfect, but it's alot faster than selecting and deleting 20 lights at a time.
sfrench ( ) posted Sat, 13 April 2002 at 2:54 PM
Try this it's in the free section only one light is left Reset Lights - a python script By: agiel Sponsor: Linfa Net Dec 12, 2001 PC/Mac 1084 downloads
lelionx ( ) posted Sat, 13 April 2002 at 4:55 PM
it's for propak,lookink for solution for p4.
