Mon, Jan 20, 1:13 PM CST
Renderosity Forums / Poser Technical
Welcome to the Poser Technical Forum
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Dec 04 2:47 am)
Welcome to the Poser Technical Forum.
Where computer nerds can Pull out their slide rules and not get laughed at. Pocket protectors are not required. ;-)
This is the place you come to ask questions and share new ideas about using the internal file structure of Poser to push the program past it's normal limits.
New users are encouraged to read the FAQ sections here and on the Poser forum before asking questions.
Subject: deleting lights in poser4
lelionx ( ) posted Tue, 02 April 2002 at 10:56 AM · edited Thu, 21 November 2024 at 1:00 PM
would like to know if there's a way to delete all lights in one clean sweep instead of one at a time. i.e. global lights i may have 20 or more lights.if i switch to another light set i don't always get the same efx as if i had started from a clean set,say with only one light.deleting all those lights is a royal pain.
geep ( ) posted Tue, 02 April 2002 at 5:51 PM
Load a "new" Poser file.
cheers,
dr geep ... :o]
edited 10/5/2019
doozy ( ) posted Tue, 02 April 2002 at 7:53 PM
But that deletes everything else, too!
ScottA ( ) posted Tue, 02 April 2002 at 8:03 PM
What about using the UI dots to save a bunch of different scene layouts with different lighting setups? ScottA
ScottA ( ) posted Tue, 02 April 2002 at 8:07 PM
Ack! never mind. UI dots don't save new lights.
Kiera ( ) posted Wed, 03 April 2002 at 12:15 AM
This is easy. ;) Save your scene with no lights or one light when you are ready to work on lighting. Try presets. If you don't like it, revert to your saved scene. :)
geep ( ) posted Wed, 03 April 2002 at 1:10 AM
Ok, then ... Load your "saved" Poser file. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Preston ( ) posted Fri, 12 April 2002 at 3:46 PM
Well, it's not a perfect solution... I took my standard light set and "turned off" all the lights by clicking off the "On" buttons in properties. I then saved this as a light set. When I want to change light sets, I click on the "Lights Off" set first, then click on the new light set. This turns all the lights off but doesn't remove them. It tends to work even when I have more lights on than I have off (if that makes any sense whatsoever). It's imperfect, but it's alot faster than selecting and deleting 20 lights at a time.
sfrench ( ) posted Sat, 13 April 2002 at 2:54 PM
Try this it's in the free section only one light is left Reset Lights - a python script By: agiel Sponsor: Linfa Net Dec 12, 2001 PC/Mac 1084 downloads
lelionx ( ) posted Sat, 13 April 2002 at 4:55 PM
it's for propak,lookink for solution for p4.
