Mon, Feb 10, 6:26 AM CST
Subject: Dont Get It
glennjan ( ) posted Sun, 14 April 2002 at 2:14 PM ยท edited Sun, 09 February 2025 at 3:20 PM
OK I want to take vicky apply body and face poses and also the Mat Poses Then be able to put the whole thing into the library so I click and Presto all set up as a character.....without making a pz3 file.....Is this a MOR file??? Any Utilities or Tutorials??? Saw something in here about putting parameters in a spread sheet ...sounds too hard for me....Easy Way???
aleks ( ) posted Sun, 14 April 2002 at 3:44 PM
jw
KattMan ( ) posted Sun, 14 April 2002 at 4:16 PM
Yep there is an easy way. There are a few utilities out there that can create this. That is the MAT MOR Pose thing in the free section. Can't remember who wrote it but I am sure you can search there for software or MAT. Also, just recently my Poser Wizard went public in the marketplace. Within it's frame work is a MAT MOR wizard that will create these files from a saved CR2.
Lovely Lady ( ) posted Sun, 14 April 2002 at 4:17 PM
What you need to do is set up your character as you like with mat poses and faces then save it under Figures, by clicking the + sign in any folder there. Name it and then Poser will make a cr2 file with all the stuff in it.
bloodsong ( ) posted Sun, 14 April 2002 at 4:34 PM
heyas; yep, pretty simple really: it's a figure file. ;) you might want to memorize the figure before you save it to the library. that way, it will recall the morph dial settings if you ever accidentally apply new ones.
KattMan ( ) posted Sun, 14 April 2002 at 4:46 PM
well yeah. It is pretty simple like that, but think about this. Every Mike character or Vicky Character you save in this fashion will require nearly 30 megs of disk space. Compare that to about 100-300KB for the same figure as a MOR pose file. That's the beauty of these pose files, saves on disk space big time.
glennjan ( ) posted Sun, 14 April 2002 at 5:04 PM
So if I take vicky change the face and body with a Mor file then pose it add textures and all and save it as a pz2 it will retain this body and face shape or will it revert to the vicky body and face.....also can I save it with the hair and or outfit and have those auto load also????
KattMan ( ) posted Sun, 14 April 2002 at 8:10 PM
You won't have the hair and props attached in a standard pz2. Remember it is a pose file after all. You could try adding them back into the resukting file, but there is no telling what the character will actually be numbered so getting the hair or prop pareted correctly may not work. Now for the other question. Let's say you have your MOR file created and apply it to your Vicky in poser. The morphs will be set to duplicate the character you saved. Now Morphs can actually be set as defaults or not. What this basically means, if you restore the figure then you rmorph settings will be lost unless the defaults for those dials are also changed.
beav1 ( ) posted Sun, 14 April 2002 at 10:55 PM
Where exactly can those of us who are t-totally stupid go to learn about or understand these MOR files??
KattMan ( ) posted Sun, 14 April 2002 at 11:00 PM
Attached Link: http://home.carolina.rr.com/kattman
well I do have an explaination of the CR2 format at my site. Go to Portals-tutorials. You will find the CR2 Autopsy listed there in four parts. The Autopsy will be updated sometime in the future but I don't have a time table for this as yet. Basically the need for the update is due to the fact that I will expand this to cover all poser files. Every Poser file follows the same exact format, but the explaination given is specfic to CR2. MOR and MAT files are really just pose files but contain only material and morph listings. Pose files are a subset of CR2 files which in turn are a subset of the Poser PZ3 file format.
